rtlambert1
Hello all,
I'm working on a project that includes a 6 story open parking garage which is non-sprinklered. After my code research, I cannot find a definitive determination if I can have a stair that does not egress directly to the outside of the building. Per IBC 2018 section 1019.3, condition 6, an exit access stair is permitted to be unenclosed for the entire height of the parking garage, and the exit travel distance can be measured to the top of the stair, essentially allowing an open exit access stair to be used as an exit stair. That part is clear, but the code is unclear on whether or not the exit access stair needs to go directly outside. Typically an exit access stair is locate inboard with the exit travel distance continuing beyond the stair to the exit door, but not in this case due to the open parking garage exception. It just seems odd that once you reach the bottom of the stair, there does not appear to be a limit on travel distance to get outside.
Because it is an unenclosed exit access stair and not a rated exit stair, the exit discharge requirements from 1028.1 don't apply.
Thoughts on whether or not there is an issue with an interior exit access stair in a parking structure not opening directly to the outside? I feel like this is a pretty common thing, but don't have a ton of experience with parking garages.
Thanks!
Thanks!
