bcm
Hello,
Could anyone point me in the direction for learning the the live load capacity for 3x5 lumber? These are the actual dimensions of the joists. This is an old house from 1905. This type of joist isn't referenced in the IRC tables, but I'm guessing the live load rating could be close to double a modern day 2x6 (which is 1.5"x5 1/2"). I'm not able to find the actual span today, but I'm assuming they are going to span to the center of the house, so this might be around 11 feet.
I'm working with a house that had an attic renovated by a prior owner, presumably without permits. I want to put a bathroom in, but am being told the floor has to be able to support 40psf. So I'm trying to understand the limits of the floor before I go in too deep. Maybe I need an engineer to consult. The joists also have wide and thick planks running across them. I'm assuming this is original to the constriction. On top of that is a layer or 1/2" flooring put down by the last owner.
Thank you.
Thank you.
