Finding Water Leaks Underground
north star
Sawhorse
This is not a Code related question...
I am seeking input related to finding water leaks underground.
We have a few facilities where we have water leaks underneath a large area
of concrete, possibly even underneath the building foundation...........Presently,
we cannot pinpoint the exact location of the leak(s).
How do the Commercial contractors perform a search to pinpoint the leak,
hopefully, without digging up a large amount of concrete & other ?........Dyes,
...concentrated scents, ...listening devices, other ?.........Also, are there
some web sites that I can review for additional guidance.
Thanks for any input !
I think listening device and cameras also. Maybe heat seeker camera also
Plus you might try a laser digital thermometer to see if you can find temp change, especially if hot water line leak.
O.K., our underground water leaks will be cold water only [ fire water & potable ].
The fire water supply line is 8 inch, the potable is 2.5 inch............One of the
lengths of piping is approx. 240 ft., ...another one is approx. 80 ft.........Both lengths
of piping are underneath concreted areas.
Much thanks for the input ya'll !.........Keep it coming. :cool:
Fire line as in sprinkler only?
Ok on the fire line and should be able to check domestic also.
Shut at street shut at building, the sprinkler line will have a gage
Check it after 1,2 ,3 hours see if dramatic pressure drop
Presently, we have not yet sought input from a Contractor with an infrared camera.
Not sure if one will be able to read thermal changes under 8+ inches of concrete,
and even more fill dirt below that.
We HAVE "kicked the idea around" about drilling listening holes, to (1) possibly
detect by sound, and (2) to see if water comes up through the hole, ...how much
pressure, etc.
From the tap from the water distribution line, there is an 8 inch supply line
entering our property.......Then it branches off to a 2.5 inch potable supply line
to the main bldg......This is one of our properties.........On another one of our
properties, the same scenario applies, but the leak is located somewhere
underneath a large concreted area, and has a bldg. on it as well........This 2nd
property has a leak, or leaks on the fire water supply line.
Again, ...much thanks for the input !
CDA is thinking along the lines that I am. Contact some of the leak detection companies in your area. Many of them have some very sophisticated equipment that should be quite capable of detecting the leaks you have under the concrete. I've used them several times in the past with great success.
Thanks all for the input !...........This information GREATLY helps me out !
We will pursue a Plumbing Contractor with Leak Detection capabilities, and
go from there. :encouragement:
  • Like
Reactions: JBI
Wow,
Plastic or ductile iron??
I think my first move would be
I think I would shut off at the tap in street or wherever and at the riser.
Should be a gage for the city water main pressure,
And see if you lose pressure. Might bump it maybe fifty over normal.
A fire sprinkler company can do it for you. That way you can rule in or out the FS line. Before you go chasing leaks
How a listening device will help in detecting the Slab Leak under the ground ?
Any suggestion ? ?
Divining doesn't actually find water... it finds vibrations in the air above water underground, like an aquifer, or in the case of a buried tank the air at the top of the tank above the contents. The vibrations move through the air to the solid material above and ultimately up to ground surface. Look up sympathetic vibration...
Check about one minute in:::
That is what they did at my house. They were about six inches off, from the actual leak!!!!
I'm using the LevelPro leak detection sensor device for a long time without any trouble and also the support team is very helpful. So you can check this device from Icon Process Controls website: https://iconprocon.com/product/ld-leak-detection-sensor/
Charles... looks like both of your posts link to iconprocon.com and suggest the LevelPro brand. Are you a rep, or just a fan of their products?
Do watch out with posting sales links, it can get you booted.
