Fire Riser Rooms
globe trekker
Are rooms where fire risers are installed, ...' required ' to have approved signage
or identification installed on the exterior side of the door in to these rooms?
Thanks! :)
How bout this.
SECTION 510
FIRE DEPARTMENT ACCESS TO EQUIPMENT
510.1 Identification. Fire protection equipment shall be identified
in an approved manner. Rooms containing controls for
air-conditioning systems, sprinkler risers and valves, or other
fire detection, suppression or control elements shall be identified
for the use of the fire department. Approved signs required
to identify fire protection equipment and equipment location,
shall be constructed of durable materials, permanently
installed and readily visible.
44
I sit corrected
we have had an admendment with specs for so long that sometimes do not read the book
hay when you have been doing it along time, you some times pull things from """Code of Hammurabi first edition""""""
