chris kennedy
Sawhorse
I have a 1hr fire wall, 3 5/8 metal studs, 24" OC, 5/8 rock on both sides. Is there a way to put 4" sq metal outlet boxes facing both directions in the same cavity?
Thanks.
Thanks.
Chris is an electrician which means that he has a 1hr. firewall.RLGA said:1. There is no such thing as a 1-hour fire wall. Is this a fire barrier or a fire partition?2. Follow the items ICE quoted.
Reads the same in the FBC, thanks.ICE said:2009 IBC but I am in California so your code may be different.
I haven't seen that in code. That doesn't mean that it's not there somewhere. If asked if an old work box could be used I would say that as long as the requirements of section 713 are met, no problem.chris kennedy said:I also recall something saying the box must be attached to a framing member, no old work cut-in boxes. Anyone know where I might find that?
Sorry, detail lists this as fire partition.RLGA said:There is no such thing as a 1-hour fire wall. Is this a fire barrier or a fire partition?
FIRE BARRIER. A fire-resistance-rated wall assembly of materials designed to restrict the spread of fire in which continuity is maintained.
FIRE PARTITION. A vertical assembly of materials designed to restrict the spread of fire in which openings are protected.
I don't really understand the difference between them.FIRE WALL. A fire-resistance-rated wall having protected openings, which restricts the spread of fire and extends continuously from the foundation to or through the roof, with sufficient structural stability under fire conditions to allow collapse of construction on either side without collapse of the wall.
Last I checked, Florida does not have one hour fire walls. They were all four hours.chris kennedy said:I have a 1hr fire wall, 3 5/8 metal studs, 24" OC, 5/8 rock on both sides. Is there a way to put 4" sq metal outlet boxes facing both directions in the same cavity? Thanks.
Wall separates structure into separate buildings. Barriers go between fire resistant horizontal assemblies (or may go from foundation and to an unrated/rated roof ).chris kennedy said:Sorry, detail lists this as fire partition. What is the difference between wall, barrier and partition?
ICE, the code section posted above item 1 limits the amount of unprotected electrical penetrations where as item 2 refers to installed as listed; the manufacturer installation for listed steel boxes is U.L. 263chris kennedy said:I also recall something saying the box must be attached to a framing member, no old work cut-in boxes. Anyone know where I might find that?
Those are holes....not boxes....
Wow
2012?
I was stupid back then
What’s that dear?
Never mind
The wife says I’m still stupid.
Changes every 3 years Chris, like some change wives?Wow
2012?
What’s that dear?
Never mind
