RBK
Bronze Member
I'm a sprinkler guy, and I design systems for a lot of large apartment buildings. It seems to be pretty common practice to divide the structure up into several "buildings" using fire walls. It has always been my understanding that these fire walls, while creating separate buildings for the purpose of calculating allowable areas, are not considered separate buildings for exiting. It has also been my understanding that a horizontal exit is only created when the distance between stairs exceeds the allowable, regardless of how many fire walls you may pass through.
However, I have recently come accross several architects and building officials that are treating every fire wall as a horizontal exit. The reason given is that every "building" needs two exits, and if it's not a stair it must be a horizontal exit.
I'm not well versed in the building code, so which interpretation is correct? I am currently working under the 2007 CBC, but any answers from those knowledgable about the 2006 or 2009 IBC would be appreciated. I assume the CBC and IBC treat the issue similarly, but I may be wrong.
