Fireplace doors and dampers
TheCommish
Charlton Ma
Section 402.4.3 of the 2009 IECC requires new wood burning fire places to have gasket door and outside combustion air.
Several mason have asked me if a Lyemance chimney top damper instead,
http://www.chimneydampersource.com/lyemancedamper.htm
There are several other similar “energy effect” dampers available
While the 2012 IECC sections 402.4.2 allows tight fitting flue dampers.
Discussion;
1) Is a chimney top damper a tight fitting flue damper?
2) Would those that are enforcing the 2009 IECC allow the top damper
3) If one was using a top damper have there been problems with warm moist air condensing in the chimney flue?
4) Other comments…
Curtis Meskus, CBO
Town of Charlton
Building Commissioner
Zoning Enforcement Officer
Code compliance and inspections, leads to non-events
1- Is a chimney top damper a tight fitting flue damper?
Regardless if it is or not, it is NOT a gasketed door as required.
2- Would those that are enforcing the 2009 IECC allow the top damper
In lieu of gasketed doors? NO
3- No
mj
thankd for moving to the correct place, I inteded it to be in eneergy code not electrical, my fat fingers don't help my spelling or clicking
