    Dismiss Notice
"Floor Area, Gross" - Roof Overhang - Porch
Discussion in 'Residential Building Codes' started by Jeremy Bair, Jun 11, 2019.
  1. Jeremy Bair
    Jeremy Bair Registered User
    Jun 11, 2019
    11
    0
    Good afternoon.
    I am having some issues with my local building / code enforcement office. There is a "shed" on my property that has a covered porch (under the same roof line). The shed has been there since ~2008 and was built by the previous property owner.
    The shed itself, measured from the inside (per the definition of "floor area") is 199 sq/ft. Local building code specifically says....
    one-story detached accessory structures are exempt from building permit provided the floor area does not exceed 200 square feet, is not used for habitable space, and does not contain plumbing or mechanical.
    The local building department wants me to permit the structure as they are including the covered porch in "floor area" as they are using the definition of Floor Area, Gross from the IBC... even though the structure has been existing for 11 years.
    FLOOR AREA, GROSS. The floor area within the inside perimeter of the exterior walls of the building under consideration, exclusive of vent shafts and courts, without deduction for corridors, stairways, ramps, closets, the thickness of interior walls, columns or other features. The floor area of a building, or portion thereof, not provided with surrounding exterior walls shall be the usable area under the horizontal projection of the roof or floor above. The gross floor area shall not include shafts with no openings or interior courts.
    There is no definition of "usable area" so they say well, the porch is capable of being used, so it is included.
    I cannot find any definitions of "usable area" in the IBC, IRC, Fire Code, Energy Code, etc... as noted to look for definitions in the IBC.
    If I can't get them to change their minds, I guess my option is to cut the porch off... and maybe leave an overhang, however I cannot find anywhere that says if the IBC or IRC have a rule / code for a "maximum" roof overhang / eave size?
    Any help would be greatly appreciated!
  2. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
    Welcome!!
  3. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
    So how did the shed police, find out about the shed???
  4. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
    There are a lot of terms in the code not defined.
    It is more you know it when you see it.
    One cities opinion::
    From these definitions it is clear that the floor or building area of a structure is measured from the interior face of the exterior walls. It is also clear that useable exterior space under a roof or other projection should be included in the floor area. However, it is clear that the square footage of exterior decks without a roof or floor above should not be included.
    https://www.sanjuanco.com/DocumentCenter/View/1673/Floor-Area-Determination-for-Accessory-Structures
  5. Jeremy Bair
    Jun 11, 2019
    11
    0
    the prior property owners had pulled a permit to move the structure and set it on a foundation... instead they sold the house, and we recently got a new code inspector who was going thru old unfinished permits and found the prior permit, and now says that the structure is out of compliance.
  6. Jeremy Bair
    Jun 11, 2019
    11
    0
    the kicker is ... the local code just says "floor area"... it does not specify NET or GROSS...
  7. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
  8. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
  9. Jeremy Bair
    Jun 11, 2019
    11
    0
    there is no 2nd story... just an attic area with rafters
  10. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
    That was my example of my norm for horizontal projection
    It appears some believe an attached patio/canopy to a shed should also be included,
    So how did the shed police find you ????
  11. Jeremy Bair
    Jun 11, 2019
    11
    0
    as stated above...
  12. cda
    cda Sawhorse
    Oct 19, 2009
    17,290
    1,151
    Well
    Sounds like three options
    Talk to the head person and see if they have some common sense
    Go through the appeals process
    Get the saws all out.
  13. mtlogcabin
    mtlogcabin Registered User
    Oct 17, 2009
    7,565
    927
    If there is a permit to place the shed on the property on a "foundation" and it is not on a "foundation" now then that maybe the only thing out of compliance, so modify the permit for what is there. The 200 sq ft is the number for the exception to require a permit. You have a permit for the structure so tell them you want to amend it. I suggest you ask to deal with a building inspector for a solution and not the code enforcement officer since he may know nothing about building codes and the number of different "foundations" you can install under a shed.
    Inspector Gift likes this.
  14. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,964
    1,012
    I'd agree with MT, you already have a permit, it is now just a matter of completing it to said permit or altering the permit....If they "expired" the permit, then you may have to renew it......OR.......make the porch "freestanding" and have 2 <200sqft structures that do not require a permit....
  15. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,253
    405
    Ah, but isn't the permit expired as it was never extended?
    Code indicates that where no clear definition is provided you revert to dictionary definitions?
    cda likes this.
  16. Jeremy Bair
    Jun 11, 2019
    11
    0
    that is why they are including it... because the dictionary says "usable" means "capable of being used" ...
  17. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    619
    183
    GUYS, the previous owner had a permit not the new one. Don't know many judges that will uphold the owner to something to old owner pulled a permit for. If over 180 days permit void. If no work done to the shed it is existing none conforming and move on.
  18. Jeremy Bair
    Jun 11, 2019
    11
    0
    Any idea where there is any legal statute for this? They are well aware that the structure was built 10+ years ago by a previous owner, and they said that does not make it exempt from needing to be in compliance with the code.
  19. mtlogcabin
    Oct 17, 2009
    7,565
    927
    There was a permit. The issue is does it not meet today's code or the code that was in effect when the permit was issued. Did the permit indicate the size of the shed and did it include the porch area. If the building department has already disposed of the plans for the project then the only thing an AHJ has to work from is the sq footage and work description on the existing permit.
    Until they tell exactly what is out of compliance and if you need a new permit to correct it you cannot make it compliant.
    Is it a building permit issue or is the accessory structure a zoning issue?
  20. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    619
    183
    Every state is different, but usually when they adopt the building code the first time the have to allow existing structures until they are changed. If yours was truly built before an adopted and no work done when the previous owner pulled the permit I don't see how they can make you do anything. If it was that easy we would make all non-complaint buildings be complaint. Now if work was done then you have an uphill battle.
Share This Page
