The clearance from grade to the bottom of floor joists in enclosed areas, such as crawl spaces under a house, is per the CRC/IRC 18"
R317.1 Location required. Protection of wood and wood
based products from decay shall be provided in the following
locations by the use of naturally durable wood or wood that is
preservative-treated in accordance with AWPA Ul for the species,
product, preservative and end use. Preservatives shall be
listed in Section 4 of AWPA Ul.
1. Wood joists or the bottom of a wood structural floor
when closer than 18 inches (457 mm) or wood girders
when closer than 12 inches (305 mm) to the exposed
ground in crawl spaces or unexcavated area located
within the periphery of the building foundation.
We have a situation where there is a concrete slab where the grade is and from the top of that slab it's about 14" to the bottom of the floor joists. We've had this situation before in doing remodel additions and there's never been an issue but now there is. The inspector wants the slab removed or pressure treated joists used. I'm trying to find a code section that addresses this issue and haven't found anything except for the one above which does in a roundabout way. Does anyone know of a more specific citation?
Any suggestions would be appreciated,
Rio
Rio
