Framing Door Openings
Francis Vineyard
Charlottesville, VA
A 2012 Virginia Residential Code amendment requires an accessible route when certain conditions are met. One of those if the hallway is wide enough to allow for a 34-inch door or case opening. How wide would the finished hallway need to be?
Thanks in advance for your answers.
R311.2.1 Interior passage.
. . . . Any doors or cased openings along such interior passage route
providing access to the areas identified above shall comply
with the following.
1. Cased openings shall provide a minimum 34-inch
clear width.
2. Doors shall be, at a minimum, nominal 34-inch
doors.
1. Where a door or cased opening, and its associated
molding or trim, is at the end and facing the
length of a hallway and the width of the hallway
is not wide enough to accommodate such doors
or cased openings.
Paul Sweet
Sawhorse
Richmond, VA
A stock split-jamb prehung door would take 3" each side, for a 40" width.
In theory, you could get a 34" door in a 36" wide hallway, but it would require a custom frame.
I won't go into details of how I feel about this amendment.
cda
Sawhorse 123
Basement
34 inches????
MASSDRIVER
Esparto, CA
Rough frame opening on a jambed door is 2" over call size. That's typical. So a 2'10" door will flush frame in a 36" framed hall. Your header will call out 5" over the door call size.
So you put the trimmers in flush with the framing, and the header has blind kingstuds behind it, so you are building a channel with the flat part as the trimmer, the kingstud then sits behind that.
Brent.
