Mr. Inspector
Doing a plan review for a residential detached garage that may be to close to the lot line per 2009 IRC 302.1:
R302.1 Exterior walls.
Construction, projections, openings and penetrations of exterior walls of dwellings and accessory buildings shall comply with Table R302.1.
1. Walls, projections, openings or penetrations in walls perpendicular to the line used to determine the fire separation distance .
2. Walls of dwellings and accessory structures located on the same lot .
3. Detached tool sheds and storage sheds, playhouses and similar structures exempted from permits are not required to provide wall protection based on location on the lot . Projections beyond the exterior wall shall not extend over the lot line .
4. Detached garages accessory to a dwelling located within 2 feet (610 mm) of a lot line are permitted to have roof eave projections not exceeding 4 inches (102 mm).
5. Foundation vents installed in compliance with this code are permitted.
TABLE R302.1
EXTERIOR WALLS
EXTERIOR WALL ELEMENT MINIMUM
FIRE-RESISTANCE RATING MINIMUM FIRE
SEPARATION DISTANCE
Walls (Fire-resistance rated) 1 hour-tested in accordance with ASTM E 119 or UL 263 with exposure form both sides < 5 feet
(Not fire-resistance rated) 0 hours ³ 5 feet
Projections (Fire-resistance rated) 1 hour on the underside ³ 2 feet to 5 feet
(Not fire-resistance rated) 0 hours 5 feet
Openings in walls Not allowed N/A < 3 feet
25% maximum of wall area 0 hours 3 feet
Unlimited 0 hours 5 feet
Penetrations All Comply with Section R317.3 < 5 feet
None required 5 feet
SECTION R202
DEFINITIONS
FIRE SEPARATION DISTANCE. The distance measured from the building face to one of the following:
1. To the closest interior lot line ; or
2. To the centerline of a street, an alley or public way; or
3. To an imaginary line between two buildings on the lot .
So where is the "Fire Separation Distance" is measured form? What is meant by the closest interior lot line? Do I measure from the actual lot line?
TABLE R302.1
EXTERIOR WALLS
SEPARATION DISTANCE
SECTION R202
DEFINITIONS
