How many of you guys check the drainage of the lot to verify compliance with the drainage plan? Usually the lots are already benched, swalls cut, berms and so on.
In our jurisdiction we require drainage plans while the builder is in the platting process. All of the lots are graded to that drainage plan prior to permits being issued.
Where the problem comes in is the code requires positive drainage away from the foundation. The builder brings in fill to elevate the foundation to provide positive drainage away from the foundation.
At this point the structure is "to code". There is no requirement for grass, so the builders call for a final. The only thing we (the inspection department) can require at this point, and it just an interpretation we have on erosion, is that we have to protect the drainage system from infiltration from erosion. We require the ROW to either have grass or curlex to protect from erosion.
The builder calls for a final, the grading plan is "to code" per the approved drainage plans, the grass is in for erosion. All is good. Then after the tag..the builder does some grading, changing the way the lot drains all all that stuff. Once a final is given, it is tee total heck getting the builder to fix anything.
How do ya'll handle this before it gets to be a problem?
