HELP powder coating HELP
cda
Basement
Not sure if I have ever done plan review for powder coating or it has been to long.
2009 IFC
1501.1 Scope. This chapter shall apply to locations or areas where any of the following activities are conducted:
3. The application of combustible powders when applied by powder spray guns, electrostatic powder spray guns, fluidized beds or electrostatic fluidized beds.
a. Can not find defintion for "Combustible Powder" in the I Code
b. Take it if I do have a true "powder coating " operation cannot use open faced booth?
SECTION 1506 POWDER COATING
1506.1 General. Operations using finely ground particles of protective finishing material applied in dry powder form by a fluidized bed, an electrostatic fluidized bed, powder spray guns or electrostatic powder spray guns shall comply with this section. In addition to :Next('./icod_ifc_2009_15_par127.htm')'>Section 1506, :Next('./icod_ifc_2009_15_par141.htm')'>Section 1507 shall apply to fixed electrostatic equipment used in powder coating operations.
1506.2 Location. Powder coating operations shall be conducted in enclosed powder coating rooms, enclosed powder coating facilities which are ventilated or ventilated spray booths
c. MSDS I am looking at does not have much information
Has a 704 of "1" Fire
Has a "MEC" of MEC >/= 26g/m3
no other testing data??
Any help would be apprecatied !!!!
Never mind found the few answers I needed, plus the coffee finally kicked in.
Appears can be done in a properly constructed booth.
And Combustible powder is defined in NFPA 33,,, NFPA 33 2016
3.3.4 Combustible Powder. Any finely divided solid coating material that is capable of being ignited.
