The Guardian said:The inquest concluded that years of botched renovations had removed fire-stopping material between flats and communal corridors, allowing a blaze to spread, and that the problem was not picked up in safety inspections carried out by Southwark council. The council was investigated over possible corporate manslaughter charges, but eventually fined £570,000 under fire safety laws.
Arnold Tarling, a chartered surveyor at Hindwoods and a fire safety expert, says the elephant in the room is the flammability of insulation panels that are being used to clad postwar buildings to bring them up to date with today’s thermal standards. A recent £8.7m refurbishment of Grenfell Tower saw the building clad with “ACM cassette rainscreen” panels, an aluminium composite material covering insulation panels, which could have caused the fire to spread more quickly up the facade of the tower.
“The issue is that, under building regulations, only the surface of the cladding has to be fire-proofed to class 0, which is about surface spread,” says Tarling. “The stuff behind it doesn’t, and it’s this which has burned.” He says he recently inspected a new-build eight storey block in south-east London where there was no fire protection in the external cavity walls. “The insulation behind the external cladding is flammable polyurethane. I know because I took a chunk out and burned it.”
“We have been very concerned about the introduction of highly combustible products into buildings,” he says. “They are often being introduced on the back of the sustainability agenda, but it’s sometimes being done recklessly without due consideration to the consequences. It’s not uncommon for buildings to have blocks of polystyrene up to 30cm deep on the outside, which is an extraordinary quantity of combustible material to be sticking on to a building. There are often ventilation voids between the rainscreen cladding and the insulation to prevent damp, but this also increases the spread of flames.”¹
Daily Caller said:London’s Grenfell Tower was made worse by government “green energy requirements” that allowed fire to rapidly engulf the building Wednesday, leaving at least 17 people dead and scores more wounded or missing.
While it’s unknown what sparked the fire, experts say that the cladding, or exterior insulation, created a chimney effect through which the fire rapidly spread upwards. The cladding was added to Grenfell’s exterior in 2015 as part of a $12.8 million retrofit.
“I have never seen a fire that has engulfed an entire building like this in a career of more than 30 years,” Matt Wrack, who heads the Fire Brigades Union, told The Telegraph.
“It could be that this is the quest for sustainability trumping other concerns,” echoed Dr. Jim Glockling of the Fire Protection Association.
“There has been an emerging body of evidence surrounding some of the materials being used and now we have an appalling demonstration of what can happen,” Glockling said.
The Telegraph noted that cladding “is used as an insulation to make buildings more sustainable to meet green energy requirements.” Some 30,000 buildings in the U.K. have been retrofitted with cladding to cheaply comply with green energy mandates.
Grenfell Tower became more energy efficient, but the space between the cladding and the building increased the potential damage from fires, leaving hundreds of residents at the fire’s mercy.
“There were explosions everywhere you looked, lots of bangs, blue gas coming out everywhere you looked,” Mickey Paramasivan told The Telegraph.
“About 12 floors up I saw three children waving from a window and then there was just an explosion and they disappeared,” he said. “They were three kids, they were banging on the windows, you could see their silhouettes and then bang, it just went up.”
Prime Minister Theresa May has called for a full investigation into what happened. Others have called for all cladded buildings to be inspected for fire hazards.
However, building residents and experts have warned about the fire risks of cladding for years. A blog post by the Grenfell Action Group in November 2016 warned that “only a catastrophic event” would bring attention to the building’s issue.
Government officials cautioned against the risks of cladding since at least 1999, according to The Telegraph.¹
If the building had not been retrofitted for energy efficiency this would not have happened.
¹ http://dailycaller.com/2017/06/15/deadly-london-tower-fire-fueled-by-green-energy-rules/
Building would not have met code here even when it was built. 2 exits minimum.
Performance based ?
