What’s the 1 1/2 for leaving the bottom of the panel?
Flexible conduit looks like a violation of working clearance.....110.26A3....Does it stick out more than 6"?
No slip joint either....on the conduit into the ground...
Not required. It is a local thing when I lived up north. Not required here. If we have frost, I'm leaving town.
If it is in a residential area I am comfortable with 10,000 amp gear but if it is not in a residential area I always ask for the AIC. I haven't asked for the label on temp power equipment.Contractors are always giving me a hard time about marking the Available Fault Current on tempory services per 110.24.
Am I asking for to much? Do other inspectors let this go?
A California professional contractor would install two ground rods and protect the G.E.C. with armor and a running board....that and receptacles rated "WR" would make the difference.
I'm curious, has that transformer been equipped with an all weather kit?
Oh right you are....I found the second rod. When I googled the catalog # of the transformer I found mention of the weather kit so, of course, I wondered about that.....Mostly because I don't know a lot about transformers. Any thoughts on the rest of it?Well, first of all. There are two ground rods visible in the picture. Next, the transformer is listed and labeled with a NEMA 3R enclosure so I don't understand what you mean.
