Remington
Plan checker came back to me with the following comment:
"show dimension of the roof eave projection along the side of the building to ensure proper distance from the interior property line"
Apparently I need to follow the following code section 705.2 Projections:
TABLE 705.2 MINIMUM DISTANCE OF PROJECTION
I cant make sense of it.
We have a 53" eave overhang. This overhang is 39" away from the property line, so I chose the 3rd row down (Greater than 3 feet to less than 30 feet) to do the associated calculations to the right of the table under "MINIMUM DISTANCE FROM LINE USED TO DETERMINE FSD":
39 inches - 3 ft = 3” = .25 (of one foot)
24” + (8”)(.25)= 48”..... so.. 48" from the property line? This makes no sense.
Minimum distance from what line?
FYI: FSD is defined as follows
FIRE SEPARATION DISTANCE. The distance measured from the building face to one of the following:
- The closest interior lot line;
