    Dismiss Notice
    Dismiss Notice
insulation
Discussion in 'Plumbing Codes' started by ICE, Jul 11, 2019.
  1. ICE
    ICE Sawhorse
    8,223
    873
    We require that a goodly amount of water pipe be insulated.
    The insulation on the right is a tight fit. The contractor used the insulation on the left which is loose. An inspector wrote a correction to replace the loose insulation with the tight fit insulation. I'm not the guy for insulation code and this other inspector is a plumbing guru whereas I'm lucky if I hit the bowl.
    So what do you guys think about this? Was it worth making them do it over. My first reaction was..... Hey now, the tight insulation has a thermal bridge and the loose insulation barely touches the pipe. Honestly, I would have never noticed.
    [​IMG]
  2. linnrg
    linnrg Sawhorse
    Mar 17, 2015
    351
    94
    trapped air is somewhat of an insulator
  3. HForester
    HForester Member
    Sep 21, 2015
    164
    52
    It is a workmanship issue. I suppose you could really step into it and get the insulation manufacturer involved to ask the question, "does this product, as installed, provide for R3 insulating properties on the pipe? (R3 is just an example requirement.)
  4. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,916
    204
    Are there manufacturers installation requirements?
  5. Inspector Gift
    Inspector Gift Sawhorse - Made in USA
    Oct 17, 2009
    251
    56
    What code section did the inspector cite?
  6. jeffc
    jeffc Bronze Member
    Oct 23, 2009
    94
    11
    Washington State requires R-3 pipe insulation for freeze protection. When I contacted the manufacturer asking about the pipe wrap r-value, she replied with:
    R value on item 3/4"- #P11X - 2.1 and 1" -P12X - 2.0.
    Thank you
    Cheryl
    Thermwell Products
    201-684-4400
    Interested in hearing someone tell you, "that is what we always use", ask about the pipe wrap r-value.
    #6 jeffc, Jul 12, 2019
  7. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    7,259
    802
  8. Sleepy
    Sleepy Registered User
    Jan 6, 2017
    94
    47
    I've always thought the insulation was to prevent condensation on the outside of the pipe and would imagine that if the insulation isn't snug to the pipe it wouldn't work for that purpose.
  9. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    7,259
    802
    In general, the outside diameter of a copper pipe will be 1/8” bigger than its nominal width. Plastic pipes will be 3/8” bigger, and cast iron pipes will be ¼” bigger. To derive the nominal width, you need to know what the pipe is made of and then subtract the correct amount.
Share This Page
