    Dismiss Notice
Joist hanger size
Discussion in 'Residential Structural Codes' started by e hilton, Dec 4, 2019.
  1. e hilton
    e hilton Bronze Member
    Jul 2, 2014
    730
    169
    IBC 2015. Where can i find the requirements for joist hanger sizes? For example ... for a 2x10 joist, are you required to use a 2x10 hanger?
  2. jar546
    jar546 *****istrator
    7,419
    605
  3. jar546
    7,419
    605
    You will a different hangar number and hangar height as you graduate from 2x4 to 2x6 to 2x8, etc. etc. until you get to 2x10 and 2x12 where some of the hangars are the same size and some are larger but most are larger (taller). It essentially seems as though the wider the joists, the taller the hangars.
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,871
    992
    Load capacity is most of what matters, but there are some notes in there about lateral restraint vs. hanger height vs. joist height....
  5. TheCommish
    TheCommish Sawhorse
    Sep 27, 2011
    899
    152
    the correct fasteners are the key to the joist hanger capacity
    my250r11 and steveray like this.
  6. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,871
    992
    You mean deck screws?o_O
    tmurray and Ty J. like this.
  7. e hilton
    Jul 2, 2014
    730
    169
    Deck screws? We always use sheetrock screws.
    Seriously ... i was aware of the simpson design info, I was asking if there is a code section that applies. Or is this a case where code says to follow manufacturers requirements?
  8. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,481
    825
  9. mark handler
    Oct 25, 2009
    10,481
    825
    Many Simpson Strong-Tie connectors have been designed and tested for use with specific types and sizes of fasteners. The specified quantity, type and size of fastener must be installed in the correct holes on the connector to achieve published loads. Other factors such as fastener material and finish are also important. Incorrect fastener selection or installation can compromise connector performance and could lead to failure.
    https://www.strongtie.com/products/connectors/wood-construction-connectors/technical-notes/fastener-types-and-sizes
    ADAguy likes this.
  10. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,871
    992
    R502.6 Bearing. The ends of each joist, beam or girder shall
    have not less than 11/2 inches (38 mm) of bearing on wood or
    metal and not less than 3 inches (76 mm) on masonry or concrete
    except where supported on a 1-inch by 4-inch (25 mm
    by 102 mm) ribbon strip and nailed to the adjacent stud or by
    the use of approved joist hangers.
    Whatever you want to approve....ICC ES or manufacturers engineering/ instructions.....Or nothing...
  11. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    607
    179
    You have no idea how many times i write that correction.o_O
    Ty J. likes this.
  12. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    4,128
    394
    What! no nails allowed?
  13. Sifu
    Sifu Gold Member
    Sep 3, 2011
    1,187
    135
Share This Page
