drappehs125
Hi all:
I'm hoping somebody here will be able to tell me the purpose of some plumbing in my basement.
This is a townhome built in the early 90s in Ontario, Canada.
Basically, in the far corner of my basement (opposite corner of my water supply and laundry area) there is a 1.5" ABS pipe sticking up out of the concrete. There is a cold water supply line (polybutylene) with a valve that is inserted directly into the ABS pipe. See the end of this post for links to images.
What is the purpose of this? When I open the water valve, water flushes down the ABS pipe. I've left the water running with the valve full open for a few minutes and the 'drain' handles it fine.
Could this be a manual "trap primer"? I don't smell sewer gas coming from the ABS pipe, but that would make sense if there were a trap below the concrete.
I'd like to know if this is connected to the sewer drain, I am considering in the future to place a small bar sink in that corner of the basement, connecting the bar sink drain directly to this mystery ABS and re-routing the cold water supply line to the sink tap - but without knowing what this is for sure I would not proceed.
The previous owner of the house had no idea what this was either, so the valve hasn't been opened in 10+ years until recently when I started investigating, so it doesn't seem too important to open this valve regularly
Any information would be greatly appreciated.
Valve:
Mystery ABS 'Drain':
Valve:
