Just to clarify steveray's post, the section quoted is from the International Plumbing Code.405.3.1 Water closets' date=' urinals, lavatories and bidets. [/b']A water closet, urinal, lavatory or bidet shall not be set closer than 15 inches (381 mm) from its center to any side wall, partition, vanity or other obstruction, or closer than 30 inches (762 mm) center to center between adjacent fixtures. There shall be not less than a 21-inch (533 mm) clearance in front of the water closet, urinal, lavatory or bidet to any wall, fixture or door. Water closet compartments shall be not less than 30 inches (762 mm) in width and not less than 60 inches (1524 mm) in depth for floor- mounted water closets and not less than 30 inches (762 mm) in width and 56 inches (1422 mm) in depth for wall- hung water closets.
Other than code minimums' date=' good practice and todays "growing" (expanding) bodies imply a minimum clear stall width of 36" with no less than 30" from the inside face of the stall door to the front lip of the stool. (preferable for door to swing out) Obesity is an epidemic and is not going away soon. Similarly taller WC's work better than short ones for ever taller folks. [/quote']The Great Obesity Epidemic of 2016, like it's Polio, like we are going to be telling our grandchildren about it someday: "How'd you get through it grandpa?" "Ohhh it was horrible Johnny, there was cheesecake and porkchops everywhere!"
No disrespect ADAguy...that was for Conarb....
Yeah Steve, but by getting obese you get those pretty blue placards that give you not only the best parking places but free parking anywhere, you can also go into Walmart or Costco and get those free motorized scooters and run around bumping into people who get in your way, just like you did as a kid when you rented bumper cars at Playland.The Great Obesity Epidemic of 2016, like it's Polio, like we are going to be telling our grandchildren about it someday: "How'd you get through it grandpa?" "Ohhh it was horrible Johnny, there was cheesecake and porkchops everywhere!"
Conarb, Do you take security guards when you enter Walmart?Yeah Steve, but by getting obese you get those pretty blue placards that give you not only the best parking places but free parking anywhere, you can also go into Walmart or Costco and get those free motorized scooters and run around bumping into people who get in your way, just like you did as a kid when you rented bumper cars at Playland.
I do not see a code section like this in the California Plumbing Code for non accessible stall dimensions? 30" minimum width? Bump! not sure why this isn't coming to the top so people see it?
Thanks Mark!402.5 Setting
Fixtures shall be set level and in proper alignment with reference to adjacent walls. No water closet or bidet shall be set closer than 15 inches (381 mm) from its center to a side wall or obstruction nor closer than 30 inches (762 mm) center to center to a similar fixture. The clear space in front of a water closet, lavatory, or bidet shall be not less than 24 inches (610 mm). No urinal shall be set closer than 12 inches (305 mm) from its center to a side wall or partition nor closer than 24 inches (610 mm) center to center
Next time you fly on an airplane check the space provided.
Also not a Airplane requirement30" can be traced way back to the original Graphic Standards.
