Sifu
- Joined
- Sep 3, 2011
- Messages
- 2,773
Codes require insulation be installed from the top of the slab down vertically and/or horizontally for the prescriptive depth. Codes also require that the exterior wall on top of this slab be 6" above the exterior grade. This means that 6" of 2" insulation will be exposed. I am having "trouble" with this application. If anyone can suggest workable methods for protecting this insulation I would be happy to hear them. So far about the only thing I can come up with is bending a kick out flashing out and over and down. That will look bad and obviously the builders I am introducing this to are not happy. I also think this will be damaged in fairly short order by a homeowner/landscaper or building owner (commercial) and then the intent of the code would be defeated anyway. I would like to come with a workable solution to make it an easier code to swallow and a lasting solution as well. Some adjoining jurisdictions have been allowing them to insulate under the slab inside the building, in fact my last jurisdiction did this as well. I never liked it because it leaves the slab edge open to direct energy transfer. Thoughts?
