    Dismiss Notice
    Dismiss Notice
Moving of a Home
Discussion in 'Residential Building Codes' started by Bender, Jan 8, 2019.
  1. Bender
    Bender Sawhorse
    Aug 27, 2018
    6
    0
    Hi all,
    I have a pre-app meeting with some homeowners and a large company to discuses the moving of a home. The home in question will be moved about a mile away and set on a new foundation. As this is my first, I would like to reach out and ask how any of you have done this. is there anywhere else to look other then the EBC chapter 13? Any advice will be appreciated. Thanks
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,143
    763
    What code edition are you on? Talk to the local inspector and see how they feel about it and what they might require...
    It has gotten less restrictive over the years:
    2003 IBC
    [EB] SECTION 3408 MOVED STRUCTURES
    3408.1 Conformance. Structures moved into or within the jurisdiction shall comply with the provisions of this code for new structures.
    2012 IEBC
    1301.2 Conformance. The building shall be safe for human
    occupancy
    as determined by the International Fire Code and
    the International Property Maintenance Code. Any repair,
    alteration, or change of occupancy undertaken within the
    moved structure shall comply with the requirements of this
    code applicable to the work being performed. Any field-fabricated
    elements shall comply with the requirements of the
    International Building Code or the International Residential
    Code as applicable.
  3. TheCommish
    TheCommish Sawhorse
    Sep 27, 2011
    759
    85
    I have done 2 house moves years ago, I treat them like somewhat like a modular or remodeling, if it exists and is not a life hazard leave it alone, if it is opened and expose a problem fix it, all new work has to comply with current code
    tmurray likes this.
  4. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    7,049
    707
    exactly what the commish said and update the smoke detectors and require them to be interconnected since they make wireless interconnected ones it is not difficult and make sure there are CO detectors also.
  5. Bender
    Bender Sawhorse
    Aug 27, 2018
    6
    0
    thanks for the replies guys.@Steveray we are in the 2015 code cycle, I am the local inspector so discussing this with myself wont get far.
  6. cda
    cda Sawhorse
    Oct 19, 2009
    15,437
    925
    Why not, does the other person not listen?
    Good luck
    Not into house moves, but I guess all the utilities at the new site have been looked at.
    What will be the end use of the building residential ??? or Other ??
  7. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,771
    273
    For a Residential Code building you should look at Appendix J of the IRC to guide any necessary repairs or alterations post move.
  8. Mark K
    Mark K Platinum Member
    May 12, 2010
    1,403
    90
    If this is in California there is a state statute, which controls over the building code, which other than the new foundation does not require that the moved house does not need to be upgraded.
  9. Bender
    Bender Sawhorse
    Aug 27, 2018
    6
    0
    Yes the Home will stay a residence, and is being moved in king county Washington.Thanks JBI i will look at that.
  10. Robert
    Robert Sawhorse
    Jan 29, 2016
    172
    18
  11. Mark K
    May 12, 2010
    1,403
    90
    California Health and Safety Codes Sections 17922.3 and 17958.9 deal with residential buildings and do not require that the moved residential building comply with the current code in all aspects.
    This is actually referenced in Division 1 of Chapter 1 of the California Building code for those who read this chapter and check out the referenced statutes.
Share This Page
