Hi All
I would like to know anybody knows if there are any contradictions to install a riser inside the fire exit stairwell to run FIOS wiring? Riser (steel pipe) would be penetrating landings at each floor (12th floors). From that riser, separate lines would be branched off into the hallways on every floor. Riser and all the penetrations would be fire-rated.
I know that IBC 1023.5 restricts some penetration and equipment at the stairwells but would this case fall under that code? Are there any other codes that would restrict such installation?
Thank you for any information
Best regards
Best regards
