    Dismiss Notice
No pull stations in Virginia
Discussion in 'Commercial Fire Codes' started by S.Johnson326, Sep 6, 2019.
  1. S.Johnson326
    S.Johnson326 Registered User
    Sep 5, 2019
    2
    0
    I recently was in a high rise office building in Virginia and noticed there weren't any manual pull stations anywhere in the building. I looked at the annunciator and pull stations wasn't listed as one of the devices. I went online and looked in the IBC 2015 edition and it states that manual stations are not required if the building is fully sprinklered. Why does it seem like every office building in the DC/MD/VA area has pull stations if they're not required?
  2. RLGA
    RLGA Sawhorse
    Oct 18, 2009
    1,722
    544
    Look at when they were built. If they were built before the IBC was first adopted, then maybe the BOCA code required them.
    Next, if they were built after the time the IBC was first adopted, look at the local amendments--they may require them regardless of sprinklered condition.
    Finally, if the other two aren't applicable, are you sure the buildings you were looking at were sprinklered?
  3. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    7,385
    855
    Exception: Manual fire alarm boxes are not required where the building is equipped throughout with an automatic sprinkler system and the alarm notification appliances will activate upon sprinkler water flow.
    Been in the IBC since 2003. Maybe a local amendment?
  4. cda
    cda Sawhorse
    Oct 19, 2009
    16,453
    1,050
    As stated year built
    Or
    Fire alarm companies make money for each device sold
    Or
    Ahj talked them into installing them
  5. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    2,181
    316
    Minor correction, I seem to recall that either 13 or 72 requires a minimum of one pull station to be installed for use in the event the fire sprinkler system is out of service. I believe it has to be installed by the fire riser.
    CDA.... am I recalling this correctly?
  6. cda
    cda Sawhorse
    Oct 19, 2009
    16,453
    1,050
    I am thinking you are right
  7. S.Johnson326
    Sep 5, 2019
    2
    0
    Thank you for the responses ! I will see what I can find In the local codes.
  8. cda
    cda Sawhorse
    Oct 19, 2009
    16,453
    1,050
    There can be a number of reasons why pull stations are installed.
  9. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    1,126
    170
    Maryland enforces NFPA 101 as well as IBC. DC might also. I expect that most engineers in the DC metropolitan area design everything to the most stringent code of the 3, so they don't get caught leaving something out.
  10. cda
    cda Sawhorse
    Oct 19, 2009
    16,453
    1,050
    Made me look, only because I required one pull in a non sprinkled building recently, and got my hand slapped.
    NFPA 72 2013 23.8.5.1.2
    Builder Bob likes this.
  11. Builder Bob
    Oct 17, 2009
    2,181
    316
    Thanks CDA...... just ran out of memory cells and did not have time to look.
    BB
Share This Page
