Nueces County airport to add trailer to comply with ADA rules
mark handler
So. CA
Current building does not have entrances or bathrooms geared toward people with disabilities
Nueces County airport to add trailer to comply with ADA rules » Corpus Christi Caller-Times
By Julie Silva
Posted November 27, 2012 at 10:46 a.m., updated November 27, 2012 at 6:01 p.m.
CORPUS CHRISTI — Nueces County plans to replace its airport terminal southwest of Robstown with a facility that is compliant with the Americans with Disabilities Act. The building does not have entrances or bathrooms geared toward people with disabilities.
Ruben Saenz, airport director, said leasing a singlewide trailer is cheaper than remodeling the building. The estimated cost to lease the trailer is $7,200 annually but the upgrade would be eligible for a 50 percent reimbursement through the Routine Airport Maintenance Program.
“It’s urgent that we comply with these necessities,” Saenz told the Commissioners Court on Tuesday.
Eventually, the county will look at a permanent facility.
Abel Alonzo, a local advocate who is in a wheelchair, pushed the county to create a commission composed of disabled residents to vet projects.
“I don’t want any taxpayer money being wasted,” Alonzo said. “They didn’t find anyone to go look at the site or that’s involved with ADA.”
Tyner Little, ADA coordinator for the county, assured Alonzo and the Commissioners Court that after the Department of Justice releases an agreement outlining deficiencies in the county, he plans to put together such a committee. Saenz said the approved trailer is ADA-compliant.
The court debated buying the trailer versus leasing it, later deciding to lease at the suggestion of Commissioner Mike Pusley.
“These types of facilities deteriorate pretty quickly,” Pusley said
The May inspection by the Justice Department was part of Project Civic Access, a program that studies buildings and procedures of local governments to ensure ADA compliance.
A voluntary agreement will be drafted by the Justice Department with a timeline and a list improvements. The department has given no indication of when the agreement will be ready.
