Buelligan
Maybe you guys can help? The IRC appendix for mobile homes states that all piers must be capped with 4" solids. Do you consider putting a 1 1/2" solid under the wood shims to be capped with 4" solid? Should the 1 1/2" be under the 4" solid? Would the concentrated load from the shim be too much for the small block? Thoughts? Thanks guys!
