Tim Mailloux
As usual I am probably over thinking this, but for multi-story buildings I have started wondering if plumbing fixture calculations should be performed as one calculation based on the entire occupant load of the entire building, of multiple calculations based on the occupant load of each floor.
It is very likely in a multi-story building you could have a floor or two with a much higher occupant density that the other floors in the building, and unless you do fixture calculations floor by floor you may not provide enough fixtures on those denser floors. The plumbing code also allows you to go one floor up and one floor down to get to a required plumbing fixture. Again, unless you calculate floor by floor how can you prove that the floors below or above have excess fixture capacity to accommodate persons from another floor?
The down side to calculating floor by floor is that the math will end up with more required plumbing fixtures than calculating by the building. This is due to the rounding. When one building calculation is performed the sub-totals (a number with a decimal) are round up once to get the total. When done floor by floor, each floors sub-total gets rounded up adding a lot of additional fixtures in a multi-story building.
