Branden Battig
I am building a garage 28' (Gable End) x 32' (depth) with a 10' overhang porch. I originally sized the porch to have 2x8 rafters (24" OC) attached 2-2x10 beams attached to 6x6 posts @8' OC.
I did not like the layout of the 8' OC and want to change to 10'8" span on the beams. I am having trouble calculating the beam size. I am in NE Ohio so I am using a 20psf snow load and 15psf dead load. I plan on finishing the underside of the porch with additional rafters and barn siding.
My burning question is the double 2x10 beam enough to span the 10'8" OC posts on the porch?
