and maybe you should not over think it and assume it is as stated. it was inspected at purchase by the inspector twice. Not only that it was inspect 2 years previous when it was sold. If it happened after inspection wertalking20+ beams all cut no blocks no nails separated, So I'm going to take that off the list now. possibly but every beam then not block it bolt it nothing. Can we be a little realistic. And the cuts are not uniform nor is the overlap. If the city inspector did not know 3 times a sale then another sale inspection a somne backed out , my sisters inspection. Would that nott be a them issue they deemed it safe the floor joist are rolling 2 are at 37 degree angles. Hence y original question.
do i go top insurance a lawyer both or neither. .... I will follow Ty's advice get an engineer there. I'm not dumb I know what I see I know its messed up I see whats happening. Her neighbor re did his fence told me ground sank 6 inches over 8 years, other neighbor sliding back door frame cracked. I know why again quarry explosions. I went to a few open houses noticed 2 things, things aren't square and everything has crown molding. So does my sister because of the ceiling cracks and separation.
I know there is a right way to go about this not sure the path me personally id assume walk in the quarry and yell them buy it out or i go door to door and create a class action, they will blame inspectors. Which pulls the city in. Dont want my sister niece and nephew living with me. Mine are out th house,
