roof insulation required on tenant upfit R-38?
syarn
Silver Member
Philadelphia, Pennsylvania, United States
2009 IECC
2200sf type IIB assembly A-2
alteration of existing tenant space at covered mall building in austin texas to salad restaurant;
does R-38 batt have to be installed below the deck minimum if insulation is added per table 502.2 (1)?
the existing roof deck is R-6.24 and the engineer & architect directed to provide R-13 batt below deck to meet the design basis of the HVAC.
is there an exemption for alterations?
Insulation entirely above deck = R20ci
Metal bldgs (with R-5 thermal blocks) = R13 + R13
Attic and other = R38
If an engineer and architect are involved why would they not take the time to perform a ComCheck?
Yes you can convert over to U Factor
502.1.2 U-factor alternative. An assembly with a U-factor, C-factor, or F-factor equal or less than that specified in Table 502.1.2 shall be permitted as an alternative to the R-value in Table 502.2(1). Commercial buildings or portions of commercial buildings enclosing Group R occupancies shall use the U-factor, C-factor, or F-factor from the "Group R" column of Table 502.1.2. Commercial buildings or portions of commercial buildings enclosing occupancies other than Group R shall use the U-factor, C-factor or F-factor from the "All other" column of Table 502.1.2.
I don't think we require it if the envelope is already in place and there is not a great deal of work going on.....on second reading, I guess if you are adding anything (R13), it should comply...
You need to look at the locally adopted Chapter 1 scoping provisions.
See 101.4.3 of the 2009 IECC for unmodified scoping--highly unlikely to have been kept intact in adotion process.
