Roof Sheathing
InspMO
Bronze Member
KCMO
Is there anyone out there that still sees lumber roof sheathing as described in R803.1 on with asphalt shingles :?:
Re: Roof Sheathing
InspMo,
I've seen some in Shawnee, Oklahoma on new home construction within the past few months. Back in the 60's and 70s; we used demensional lumber (boards) for roof and shiplap for sub-flooring. We installed shiplap diaganoly for sub-flooring; and then added plywood sheathing or hardwood flooring on top. Had no clue that there even was a code, much less Section R503 requirements. Maybe they came by and took pictures and notes. :)
An advantage of using demensional lumber (spaced using 8d nail) on the roof; was that roof leak damage was usually confined to small areas where you could cut out the bad spots and replace it with just a small length of board.
Uncle Bob
Re: Roof Sheathing
Sadly, no I haven't seen any on new buildings.
Most of the repairs to older buildings replace it with OSB or plywood.
On those older buldings I often see shiplap used for the wall sheathing as well as the roof and sub-flooring. Typically with cement/concrete remnants on them as the boards were first used as forms to pour the foundation walls, then re-used as sheathing.
Talk about limiting waste on a project! Or should I say 'green building techniques'... :eek:
Re: Roof Sheathing
InspectMo, We have a few houses in Willow Springs Mo. using this.
Re: Roof Sheathing
Not on roofs but I installed a diagonal plank subfloor on a house in 1977!
