Sealing the "top of exterior walls"?
Glenn
Corporate Supporter
Denver
IECC Table R402.4.1.1 or IRC Table N1102.4.1.1
"The junction of the top plate and the top of exterior walls shall be sealed"
What junction do you believe this is referring to? What part of the "top plate" seals to what part of the "top of exterior walls"?
steveray
Sawhorse
West of the river CT
I would think sheathing and plate. I know they guys around here started using a sealer at the interior of the top plate at the drywall to meet the air leakage stuff....So maybe the outside now too to reduce even more?
  • Like
Reactions: JBI
JBI
The Empire State
Where walls meet floors and ceilings need to be air sealed, same as around fenestration products.
Poorly worded as I believe the top plate IS the top of the exterior wall... probably should read top plate to ceiling and bottom plate to floor.
Glenn
Corporate Supporter
Denver
Referencing my attached photo: I have seen a few builders do this with a few different products (seal the drywall to the top plate, but at every single wall, even interior). They were all building above energy code homes, so I assumed it was part of that program and their own stringent performance expectations. I thought maybe this is what the code above is referring too, but the wording is so horrible, that I'm not sure.
  • Like
Reactions: JBI
Elior Rosenkrantz
Philadelphia, PA
I do blower door testing and when they fail I perform an energy audit. Basically depressurize the home and walk around with a thermal imager to detect the air leakage.
I can tell you first hand the most leakage come from where the outside walls meet the ceiling is always the leakiest part of the home. The insulation companies don't seem to be stuffing enough insulation into those areas. They are harder to reach and of course more time consuming.
Ori Rosenkrantz
LocalEnergyAudits.com
BlowerDoorTester.com
mark handler
Sawhorse
So. CA
