Secondary Condensate drain termination
John shane
1. An auxiliary drain pan with separate drain: an auxiliary condensate drain pan at least 1.5" deep and at least 3" larger than the length & width of the appliance beneath which it is placed, using corrosion-resistant material of adequate thickness (0.7mm galvanized metal or 1.6mm non-metallic e.g. plastic) with a separate drain installed under the equipment and discharged to a conspicuous point that will alert building occupants to a blocked primary condensate drain
What exactly is a conspicuous point? Where is it permitted to terminate.
