Re: Sewage inspections
We (the County) have just started our municipal sewage system in the unincorporated areas of the county. The new system services approximately 350 households in a population of 15,000. As County Building Inspectors we do all the installation inspections. We have huge areas of the county that aren’t able to be services by this system.
So as you can probably tell, we have a lot of individual septic systems. As a County Building Inspectors, we determine soil viability for ISDS on a lot by lot basis, issue permits, inspect installation, and issue completion permits of residential systems only using standards set by the State, and Uniform Plumbing Code. The is no actual County Health Department here. The State Health Department takes care of resturant inspections, and that type of thing.
All commercial systems are engineered, and some of our local area soils require some of the ISDS be engineered. The State NDEP handles all permits and inspections for engineered systems.
Our department handles all complaints of all septic/sewer failures. We work the complaint for any failed system, but if the system was engineered and needs new engineering, then NDEP takes over. Kind of a convoluted system, but 5 years into it, it seems to be working.
