Smokey
Hello, I have a 4800 sq ft commercial (mixed use) building built in the 1950's with a restaurant and tap room on the bottom floor and a single 1000 sq ft apartment on the second floor. I am in the process of upgrading the upstairs by renovating the kitchen area replacing the windows from single pane and installing new flooring material . This is in a small town of around 300 people, in Washington State. The part time building inspector stopped by yesterday while I was swapping out the front window and told me that I needed to pull a permit to change out the window (which I did that day, even though their permit did not list windows anywhere and I had to write it in and put an estimated cost) He also told me that I would need to install a sprinkler system in the upstairs as well as the entire downstairs if I wanted to use the upstairs space as an apartment/second home. I told him that I thought that only applied to new construction building over 5000 sq ft. not existing units. He said it applies to all mixed use commercial/residential space. I said that I was not doing any major remodeling only fixing the place up a bit, he said it did not mater, and if I wanted the city to permit it as residential upstairs I would need to install a sprinkler system, otherwise it could only be used for storage or office space with no sleeping area. When I look at the code I can not find what he is referencing can anyone help me?
