Is the rise from grade onto the first step calculated in the total rise of a stairway?
Example: If you have 26" of rise and you calculate a total of 4 risers including the grade to first step, does the handrail requirement kick in. Section R311.7.8. I have been told that the first step starts the calculation which I think is incorrect. I believe the rise starts at grade so the first step rise from grade should be counted as the fourth rise, requiring the handrail.
Your thoughts?
Your thoughts?
