Hey guys I need some feed back with this. Atached you see a drawing of a grade level basement entrance. The foundaton is Superior walls 8"2" high. I cannot find anything in the code that address these walls. My permit , under 2006 IRC R403.1 says "or approved structure systems" and R403.1.4.1. says wall must extend below frost line. The company tells me there are two ways to get the footing below frost line, about 48", Bradford Co. PA. Either put a 10"2" wall where exposed and excavate down to 48" , put 24" 2b stone and the longer wall on top. Or put a 48" frost wall below grade and your regular 8'2" wall on top. I was told builders do it both ways since the additional 24" stone for the 10"2" walls is considered a footer sub base. I cannot find anything in the code that deals with this. So, do I "assume" both ways are to code since I am sure both methods have been insp. in the past these and these are the manufacturers instructions?? All the people I talk to give a different answer but I would like to see what the code has to say! What are your feelings?Thanks!
/monthly_2011_01/11.JPG.859a867b58d095b81a8adccc22d4355b.JPG
