steve altman
I have a 3" drain line that services a WC, Lav and Shower. I have a 1.5 inch vent to the roof above the most upstream fixture (lavatory). The shower is next downstream with the WC at the most downstream end of the line. Here is the question, my shower trap arm is 6" above the wet vent/ drain. It connects by elbowing down 90degrees and then turns 90 degrees horizontally to enter the drain. Is this allowed? Normally if the shower trap arm enters the wet vent horizontally, this arrangement would be OK. A plumber friend of mine wasn't sure because of the jog down from the trap.
