manifold
IBC 2015. A question has come up whether or not we can use high (8'+) shelving to define an egress path past/through a storage room. The owner wants to install shelving with a solid backing (drywall or plywood) to create a hall to access an exit door and restroom. Corridors are not required to be rated. Would the shelving & backing be adequate to delineate the path or would a permanent wall & door be required?
