Greetings all! Thank you all in advance for your help. Next thursday we are closing on a house which is mostly a gut/remodel. It is a 2 level (1000 sqft main floor with 1000 sqft unfinished basement.) As it sits the the previous owner had removed a wall between 2 bdrms making a it a 2 bdrm home. It is listed in the county records as a 3 bdrm. The problem is, when the septic was installed in 1986 it was listed as a 2 bdrm on the permit. It is listed as a 3 bdrm in county records. we looked in to having the septic upgraded however there is no room on the property to install it due to location of wells and neighbors septics. we were told by the septic contractor that it may cause an issue if a bedroom was added(as far as the county was concerned.) He assured us that the system could indeed function for a 3 bdrm house and was merely a paperwork issue. The system installed was 1000 gallon tank with a 6 ring seepage pit(according to the permit.) The plan is to remodel the main floor and return it to 3 bdrms. My concern is that it could raise eyebrows with inspectors when pulling permits and having work done. Any input is greatly appreciated.
