Hyrax4978
Has anyone seen a wall construction that is UL listed, wood framed, 1 hour, and can be constructed from one side. Say either for a shaft wall, or up against an existing structure where you cant physically get the sheetrock installed on the back side?
Similar to a typical shaft wall with metal studs, but utilizing only wood? without the added metal framing?
