would you require engineered dwgs.?
BSSTG
Gold Member
Seadrift, Tx.
Greetings all,
Bulf fuel storage and transfer. 4-6,800 gallon tanks. 2 for diesel and 2 for gas. high wind area 110mph 3 second gust exposure C. containment required as they are not double walled tanks. 09 fire and bldg codes. located in Tx.
I have consulted with several fire inspectors, fire marshalls and like and all agree that engineered dwgs are needed. The fuel company owner is throwing a wall eyed fit with the county judge, mayor etc. that I told him I required eng dwgs. Now if I were an expert in this field I might not, but, I know little of bulk fuel storage and transfer. To top that off there is no one else in this one horse town that knows more about this than I do.
Opinions?
thanks a bunch
Byron
It is within the realm of the codes to require a design professional when it is beyond the scope of the codes or your level of knowledge..... See
IBC 2006 ed.
INSPECTIONS
104.4 Inspections. The building official shall make all of the
required inspections, or the building official shall have the
authority to accept reports of inspection by approved agencies
or individuals. Reports of such inspections shall be in writing
and be certified by a responsible officer of such approved
agency or by the responsible individual. The building official is
authorized to engage such expert opinion as deemed necessary
to report upon unusual technical issues that arise, subject to the
approval of the appointing authority.
Construction Documents
106.1 Submittal documents. Construction documents, statement
of special inspections and other data shall be submitted in
one or more sets with each permit application. The construction
documents shall be prepared by a registered design professional
where required by the statutes of the jurisdiction in
which the project is to be constructed. Where special conditions
exist, the building official is authorized to require additional
construction documents to be prepared by a registered
design professional.
IFC 2006 (BEST ANSWER FOR YOUR APPLICATION)
104.7.2 Technical assistance. To determine the acceptability
of technologies, processes, products, facilities, materials
and uses attending the design, operation or use of a building
or premises subject to inspection by the fire code official,
the fire code official is authorized to require the owner or
agent to provide, without charge to the jurisdiction, a technical
opinion and report. The opinion and report shall be prepared
by a qualified engineer, specialist, laboratory or fire
safety specialty organization acceptable to the fire code official
and shall analyze the fire safety properties of the design,
operation or use of the building or premises and the facilities
and appurtenances situated thereon, to recommend necessary
changes. The fire code official is authorized to require
design submittals to be prepared by, and bear the stamp of, a
registered design professional.
steveray said:
YES.....and tell him 3 sets! :)
And when you tell him say "Your going to need to supply us with... hold on let me see..." then clop your foot down three times "yep that would be three sets, yes sir in deed three."
Yes to engineered drawings.
clomp, clomp.....two wet stamped sets here, four copies. ;)
Greetings again,
Well it looks like everybody is seeing it my way now. Engineered plans on the way. So that's good. That said, this is another fine example of the longer you live, the more you learn about stuff that you never wanted to know anything about. So here we go with a bulk storage/transfer facility.
thanks for the help!
BS
Check Here cause in RI if plans are submitted "In accordance with state law" the practice of engineering as defined requires plans and stamps CLOMP CLOMP CLOMP. aor sometimes called Seals, Sealed etc: Ourght! Ourght! Ourght!
2) Act--The Texas Engineering Practice Act, Chapter 1001, Texas Occupations Code.
(30) Professional engineering--Professional service which may include consultation, investigation, evaluation, planning, designing, or direct supervision of construction, in connection with any public or private utilities, structures, buildings, machines, equipment, processes, works, or projects wherein the public welfare, or the safeguarding of life, health, and property is concerned or involved, when such professional service requires the application of engineering principles and the interpretation of engineering data.
(31) Professional engineering services--Services which must be performed by or under the direct supervision of a licensed engineer and which meet the definition of the practice of engineering as defined in the Act, §1001.003. A service shall be conclusively considered a professional engineering service if it is delineated in that section; other services requiring a professional engineer by contract, or services where the adequate performance of that service requires an engineering education, training, or experience in the application of special knowledge or judgment of the mathematical, physical or engineering sciences to that service shall also be conclusively considered a professional engineering service.
This should get you there but you may need a Texas Lawyer
http://www.statutes.legis.state.tx.us/SOTWDocs/OC/htm/OC.1001.htm
BSSTG,
Since RDP plans are going to be submitted, are you qualified to perform a
Special Inspection on the designed "containment area", in a High Wind
Zone?
From the 2009 IBC, Section 1704.1 - GENERAL:
1704.1 General. Where application is made for construction as described in
this section, the owner or the registered design professional in responsible
charge acting as the owner's agent shall employ one or more approved agencies
to perform inspections during construction on the types of work listed under
Section 1704.......These inspections are in addition to the inspections identified
in Section 110.
The special inspector shall be a qualified person who shall demonstrate
competence, to the satisfaction of the building official, for the inspection of
the particular type of construction or operation requiring special inspection.
The registered design professional in responsible charge and engineers of record
involved in the design of the project are permitted to act as the approved
agency and their personnel are permitted to act as the special inspector for the
work designed by them, provided those personnel meet the qualification
requirements of this section to the satisfaction of the building official. The
special inspector shall provide written documentation to the building official
demonstrating his or her competence and relevant experience or training.
Experience or training shall be considered relevant when the documented
experience or training is related in complexity to the same type of special
inspection activities for projects of similar complexity and material qualities.
These qualifications are in addition to qualifications specified in other
sections of this code.
Exceptions:1. Special inspections are not required for work of a minor nature or as
warranted by conditions in the jurisdiction as approved by the building
official.
2. Special inspections are not required for building components unless
the design involves the practice of professional engineering or architecture
as defined by applicable state statutes and regulations governing the
professional registration and certification of engineers or architects.
3. Unless otherwise required by the building official, special inspections
are not required for Group U occupancies that are accessory to a
residential occupancy including, but not limited to, those listed in Section 312.1.
Great catch North Star.
We require that a special inspection agreement document be signed as provided by the ICC's Model Program for Special Inspection appendix A.
We have only approved 15 special inspection agencies, and none are approved for all 14 areas. #13 The Special Cases area can only be approved on a case by case basis. Your situation would most likely be one of those areas.
1. what are they doing with the tanks??? What process is involved??
Is it storage only or will they be used in some process
2. Sounds like you really need a third party review of what is submitted
Just pull ip the video of waxahchie and show the higher ups, and ask them do you want this to happen in Your city or do you want as much protection as is allowed
BSSTG said:
Greetings all,Bulf fuel storage and transfer. 4-6,800 gallon tanks. 2 for diesel and 2 for gas. high wind area 110mph 3 second gust exposure C. containment required as they are not double walled tanks. 09 fire and bldg codes. located in Tx.
Opinions?
thanks a bunch
Byron
I have a State contact that I refer to when these come up (State requires separate permit too). They have some pre-engineered design/requirements they default to on smaller tanks, otherwise they require engineering too. In my opinion you are well within your rights to require additional information/engineering. I would check with adjacent jurisdictions to see if you are being consistent or if you are standing alone...while I don't want it to have an effect on how we enforce the code, politically it goes a long ways.
