Forum Coordinator
Scenario:
A homeowner has an existing obsolete panel (Zinsco) that has a 100A double pole OCPD which feeds a dock pedestal. The homeowner applied for a permit to add a meter to the circuit in order to measure electric usage at the dock since she rents it out and the permit was approved. You arrive as the electrician is closing finishing up placing the meter in the socket and notice that there is an old Zinsco 100A breaker on the ground and a "newer" looking one that has been installed. When you question the electrician he states that the old circuit breaker only shut down 1 leg and had to be replaced. The rest of the installation looks good with the added meter base and associated wiring, grounding.
Knowing that under the 2014 NEC 555.3 a maximum ground fault protection of 100mA is required for feeders to docks, would you require that this code be met?
Does the fact that the feeder OCPD was replaced affect your decision?
Does knowing that Zinsco does not make an OCPD that meets NEC 555.3 affect your decision?
Would this installation pass or fail?
