Pioneer Tom
I signed a contract with an electrical contractor to install a dedicated service for an X-ray. The contractor claimed to have done many x ray installations, he filled out the permit as a 100 amp electrical service and told me to take it down town and pay for the permit. Initially he installed #2 aluminum for this 90 foot run, it failed, inspector asked for spec sheet on X-ray machine, contractor replaced with #1 aluminum without consulting specs, specs require 2/0 copper only and a 100 Amp disconnect ( this is required by essentially every x-ray manufacturer as it has to do with most modern machines change the AC to DC and in doing so you have hundreds of amps flowing for a few milliseconds each time the rectifyer diodes open to feed a capacitor bank, somehow induction in the line is the other explaination of the oversize [see ampacity tables] wire and additionally aluminum apparenty produces harmonic chatter that disturbs the high frequency inverter that takes the DC to a high frequency AC that allows the use of a much smaller transformer than was formerly used to produce the 125 kilovolts to the X-ray tube), install failed to pass second time, contractor appealed to manufacturer to approve his install, manufacturer refused and said warranty would be voided and x-ray machine would probably need to be derated if installed, install failed to pass 3rd time, contractor threatened to appeal code officials decision ( which contractor had done successfully with this inspector in past), code official folded and passed install. Now I have a useless installation that the contractor is demanding payment on. Because the code official passed it I will now have to hire an expert witness and take time out from work myself to go to court numerous times if he presses to be paid for his useless installation. I need to keep this inspector happy in my town but he's put me in a mess by passing this (he passed it after 3 months on the 27th). What can I do. Can I appeal the inspectors decision? Again the permit app only mentions only a 100 amp service but the contract between myself and the contractor mentions the X-ray machine. HELP PLEASE.
Sincerely; Pioneer Tom.
