Yard box (gas shut off valve) identification?
insp steve
Riverside, California
I am stuck on this one... the contractor installed a cast Iron lid (8" dia) on the, gas shut off valve, yard box. He ground off the existing label (cast raised label). I need help locating the code section that requires labeling.
NOTE: this is not the main (metered) valve at the street. This is a new valve tapped into an existing medium pressure natural gas 3" line, connecting the new science wing on an existing campus, that is buried 2' below the surface. There is also and SOV at the building exterior, where it enters above ground.
PS, I will also post this in the other forum.
thanks,
steve.
insp steve said:
I am stuck on this one... the contractor installed a cast Iron lid (8" dia) on the, gas shut off valve, yard box. He ground off the existing label (cast raised label). I need help locating the code section that requires labeling. NOTE: this is not the main (metered) valve at the street. This is a new valve tapped into an existing medium pressure natural gas 3" line, connecting the new science wing on an existing campus, that is buried 2' below the surface. There is also and SOV at the building exterior, where it enters above ground.
thanks,
steve.
If this is before the meter would it not be coverd by D.O.T regulations?
