Zip Ties On Flex Ducts
globe trekker
I have seen a lot of the plastic type zip ties [ cable ties ] used to secure the flexible UL-181
ducting to the HVAC unit housings. Are they an approved means of fastening the ducting
to the housings , or is the UL-181-B-FX type tape the ' ONLY ' approved means of securing
the ducting to the housings? What are ya'll seeing / allowing? :) Also, code sections
please!
http://www.builderdepot.com/browse.ihtm ... oreid=9957
Re: Zip Ties On Flex Ducts
I appove Zip-ties for the flex ducting when taped with the right duct tape.
Rick
What about ' JUST ' the zip ties and no tape? :eek:
Isn't the UL-181-B-FX tape ' required ' ? Again, please cite applicable code sections. We are on the
2006 I-codes.
2006 I-codes.
The tape is to stop air leaks and I know Washington State Energy Code is going in that direction with leaks in heat ducts.
Rick
See Section 603.9 of the 2006 IMC. "Duct connections to flanges of air distribution system equipment shall be sealed and mechanically fastened."
GPE
Thanks to you all for your input!
Please forgive me for not clarifying my question a little more... My OP was in regard to residential
applications. Most commercial projects around here DO seal with the approved ' foil
backed ' type of tape or other approved fastening materials. Its the residentail that I have
questions about. If I am going to fail an inspection because the type of tape is not applied,
then I need to be able to cite code chapter and verse, or in the SMACNA manual or other.
gpe,
Since my question revolves around the residential side, is there something in the IRC that you
can reference?
JayHawkInspector,
Excellent reference! ;)
JayHawk,
If I am understanding you correctly the question is if tape is used on flex duct does it have to be marked "181B-FX" and according to IRC 2006 edition section M1601.3.1 yes it would for pressure-sensitive tape or "181B-M" for mastic.
gpe ( and others ),
In delving in to this conudrum further... Section N1103.2.2 Sealing. " ...shall comply with Section 1601.3.1".
Section M1601.3.1 Joints and Seams. "Joints of duct systems shall be made substantially airtight by means
of tapes, mastics, gasketing or other approved closure systems. Closure systems used with rigid fibrous glass
ducts shall comply with UL 181A and shall be marked “181A-P” for pressure-sensitive tape, “181 A-M” for mastic
or “181 A-H” for heat-sensitive tape. Closure systems used with flexible air ducts and flexible air connectors
shall comply with UL 181B and shall be marked “181B-FX” for pressure-sensitive tape or “181B-M” for mastic.
Duct connections to flanges of air distribution system equipment or sheet metal fittings shall be mechanically
fastened. Mechanical fasteners for use with flexible nonmetallic air ducts shall comply with UL 181B and
shall be marked 181B-C. Crimp joints for round metal ducts shall have a contact lap of at least 1½ inches
(38 mm) and shall be mechanically fastened by means of at least three sheet-metal screws or rivets equally
spaced around the joint.
Ch. 11 - The Energy Chapter did not specify any type of energy retention requirements.
I recently did an inspection on a residential HVAC system and noticed that the plastic zip ties were used
to fasten the flexible Return Air ducting to the Return Air register. It was one zip tie, with 2 sheet metal
screws in it, ...but no UL-181-B-FX tape.
Should there have been the UL181-B-FX pressure sensitive tape over those zip ties and not just the zip
ties themselves? M1601.3.1 seems to indicate this, ...yes? :?:
