dturn
I have a building that will have ductwork in the crawlspace. The architect is going to put gyp board on the underside of the existing 2x10 floor joists to make it 1 hour fire rated. The ducts will penetrate the bottom of the gyp board and terminate in a grille at the floor. Looking at the California Building Code, I see this as a through penetration that requires a fire damper. Problem is, all the fire dampers able to be horizontally installed only mention concrete or masonry floors, not a wood floor assembly. Are there fire dampers for a through penetration in a wood floor assembly? Does it matter that the floor is wood as long as it can be properly framed and secured?
