For a month or so, we have been prepping our mother's home to sell it. De clutter, empty it pretty much. It has been slow going.....occasionally emotional.Re: Foundation Repairs....Permit Required?
'Releveling' here is done on mobile and manufactured homes that were installed prior to mid-nineties, when 'park set' M/Us were allowed within the city limits. We require a permit, plans, and an inspection when the retrofit engineered tie down system is installed to meet seismic requirements.
As to regular homes, we don't have repairs per se but I have had several foundations put in under homes, including mine, that were built 'without' a foundation because it was under the old codes. Lots of homes on rocks, mine was about 3' in the air on pier and post. None exactly seismically sound.
Sue
This home was built in the earliest 1930s. It is a real "charmer" in a highly desirable neighborhood. Homes rarely remain on market more than a few days to a few weeks.
However, there is a problem with concrete walls of the basement. A major crack running across the wall on one side, and that wall is buckled a bit.
What to do? What contractor's recommendation to go with foundation repair orleans? And choosing the contractor? Or, do a sell "as is"? And show the quotes, or let potential buyer decide what to do?
Home value about 225k-ish.
Why do voluntary repairs not need a permit? By this logic because I decide to voluntary build a building a permit is not required.Re: Foundation Repairs....Permit Required?
We require permit for structural foundation repairs. We do not require permit for minor crack repairs or seismic retrofit as they are considered voluntary, however we will issue a permit upon request.
Just because a building permitted under a previous code is not considered seismically sound does not provide sufficient justification for a mandatory retrofit. In California a building permitted according to a previous code and maintained in compliance with that original permit cannot be required to be upgraded to an new code unless the Legislature has so provided. Additions and alterations are treated differently.Re: Foundation Repairs....Permit Required?
Sue
I would require a permit and an engineered sealed plans for the repairsFor a month or so, we have been prepping our mother's home to sell it. De clutter, empty it pretty much. It has been slow going.....occasionally emotional.
What to do? What contractor's recommendation to go with? And choosing the contractor? Or, do a sell "as is"? And show the quotes, or let potential buyer decide what to do?
I would sell as-is, priced down a little to compensate for the bad foundation. Let the buyer decide what to do.For a month or so, we have been prepping our mother's home to sell it. De clutter, empty it pretty much. It has been slow going.....occasionally emotional.
I am dealing with a client with a similar situation- large horizontal cracking of the foundation walls in 2 corners of the house, I believe cause by frost jacking of a portion of the foundation that was not sufficiently frost protected by soil.For a month or so, we have been prepping our mother's home to sell it. De clutter, empty it pretty much. It has been slow going.....occasionally emotional.
I don't see a need for a permit to repair a foundation. The foundation can fail and still be legal. Anything done to improve the foundation is over and above what the code requires.
Consider this: An owner decides that the footing should be deeper than it is.....it is at the code prescribed depth but the owner wants to add two feet of underpinning. Is a permit required?
Seismic retrofit is a thing here in California. No permit is required yet most companies get a permit. I suppose that is driven by a desire to show an insurance company that the work was legitimate.
The CEA program is a voluntary program which means that if you dont play by their rules you do not get the benefits of the program. This is not a regulatory program.Under the CA State Earthquake Authority they must get a permit from your local building department.Permit & Building Department Information CEA Brace + Bolt | CEA BB
Once you have registered in the CEA BB program, but before you begin your retrofit, either you or your contractor must get a permit from your local building department. The requirements for different building permits may vary. For instance, some building departments' permits are only valid for...www.earthquakeauthority.com
It was licensed structural engineers that decided to exempt seismic retrofits.I find it interesting that unlicensed individuals are determining what engineering repairs/retrofits require a permit.
Don't be a silly Sally. You should always ask the nurse which doctor she would allow to work on herself. It is best to not trust a surgeon as they have an itch to cut.I assume that they consult with a nurse rather than a doctor before deciding on the need for surgery.
