Understanding Flood Zones and Base Flood Elevations in Coastal Areas
Forum Coordinator
Somewhere Too Hot & Humid
The following information was put together with help from FEMA's guide HOME BUILDER’S GUIDE TO COASTAL CONSTRUCTION
Living in coastal areas can be incredibly appealing, but it also comes with its own set of challenges, especially when it comes to flooding. To effectively mitigate flood risks and ensure the safety of coastal buildings, it's essential to understand flood zones and base flood elevations (BFEs).
What Are Flood Zones?
Flood zones are geographical areas that represent different levels of flood risk. They are typically depicted on Flood Insurance Rate Maps (FIRMs) and are classified based on the likelihood and severity of flooding during specific events. Here are some common flood zones you might encounter in coastal areas:
  1. Zone V: This zone includes areas closest to the shoreline, including the Primary Frontal Dune (PFD). It is subject to storm wave action, high-velocity flow, and erosion during 100-year storm events.
  2. Zone VE: Similar to Zone V, Zone VE includes the Base Flood Elevations (BFEs) provided on the DFIRM. It also indicates an additional hazard associated with storm waves greater than 3 feet and includes the PFD.
  3. Zone A: Areas in Zone A are subject to flooding during the 1-percent-annual-chance flood. Flood conditions are less severe compared to Zone V and MOWAs due to lower wave forces.
  4. Zone AE: This zone depicts BFEs on the DFIRM. Further details can be found in the Flood Insurance Study (FIS) for areas where hydrology and hydraulic modeling were performed to determine flood hazard risk.
  5. Area of Moderate Wave Action (MOWA): This area is landward of Zone V or landward of an open coast without a mapped Zone V. During base flood conditions, the potential wave height in this area is between 1.5 and 3 feet above the 1-percent-annual-chance stillwater flood depth.
  6. Zone AO: Areas in Zone AO are subject to shallow flooding or sheet flow during the 1-percent-annual-chance flood. They are often found on the landward slopes of shoreline dunes and overtopped structures.
  7. Zone AH: Zone AH includes areas subject to inundation by 1-percent-annual-chance shallow flooding, usually in areas of ponding. The average depths in this zone range between 1 foot and 3 feet.
  8. Zone X: This zone represents areas with a lower probability of flooding, typically less than 1%. These areas are generally not regulated through community floodplain management ordinances and building codes due to their lower predicted risk of flooding.
Understanding Base Flood Elevations (BFEs)
The Base Flood Elevation (BFE) is a critical component in flood zone determination. It represents the predicted elevation of floodwaters and wave effects during the 1-percent-annual-chance flood, also known as the base flood. BFEs are typically referenced to a specific vertical datum, such as the 1988 North American Vertical Datum.
For coastal buildings, the BFE plays a crucial role in determining the minimum lowest floor elevation and the foundation type and design for new construction. These requirements are essential for ensuring the resilience of coastal structures in the face of potential flooding.
Conclusion
Understanding flood zones and base flood elevations is vital for coastal building planning and construction. It helps communities and builders make informed decisions about the design and safety of structures in flood-prone areas. Whether you're a homeowner, builder, or part of a local community, being aware of these factors is key to reducing flood risks and ensuring the long-term sustainability of coastal buildings.
