T-Bird, I do appreciate what you are saying about these codes having been written prior to the concept of mixed use structures with the residential use above the floodway.
You might want to check with Kirkland and see how they allowed it in the past. Is your flood control systems handled at the municipal jurisdictional level, or at a county level? Is there a variance process available, such as at Clark county?
To clarify:
- The “Floodway” includes the channel of a river or other watercourse and adjacent land areas that must be reserved in order to discharge the base flood without cumulatively increasing the water surface elevation more that one (1) foot.
- The “Floodplain” or “Floodway Fringe” is the land area between the floodway and the limits of the one hundred (100)-year floodplain. The floodplain elevation is also known as the base flood elevation.
I think the goal behind "no residential in a floodway" is that when a big rain occurs, public safety officials can encourage everyone to "stay home today", without getting a bunch of 911 calls saying "help, I'm trapped in my home by flood waters". So in the case of your particular site, is there a portion of the site located outside the floodway, where all of your upper (residential) levels could have their exit discharge onto land that is not in the floodway during a base flood? That may help your case a lot.
